ASIO Bridge for 64bit?
cjunekim
Postby cjunekim » Tue Jul 24, 2018 11:31 am
ASIO Bridge control panel program(VBCABLE_AsioBridge.exe) is installed only for 32bit. Hence, I cannot utilise any ASIO drivers for 64bit with ASIO bridge. Do you have any plan to provide 64bit exe file for ASIO Bridge?
Re: ASIO Bridge for 64bit?
Postby Vincent Burel » Fri Aug 03, 2018 9:07 am
audio board manufacturer are intended to provide 32bits ASIO interface as well on 64bit O/S. contact your audio board manufacturer.
Users browsing this forum: No registered users and 14 guests
