Can Voicemeeter Help with Complex Setup?
turd_rotisserie
Post by turd_rotisserie »
Abbreviations:
REASON = A well known DAW
ExtS = Physical External Soundcard - there are two of them, #1 & #2
MULTITRACK = Multitrack Recorder DAW
Ch. = Channel
BORING DAW = just a different DAW
THE SETUP :
[NOTE: ExtS #1 is a general use device with 4 stereo I/O channels selectable by computer-->USB (ASIO), or by phono lead]
[NOTE: ExtS #2 Ch.3/4 is a sort of universal cue channel, it is listened to via one pair of physical headphones]
REASONs main output rack channels --> [using ASIO4ALL] --> MULTITRACK Instance #1 (1 MULTITRACK channel per Reason rack device) --> [using ASIO4ALL] --> ExtS #1 Ch.1/2
REASON's cue track --> [using ASIO4ALL] --> MULTITRACK Instance #1 --> [using ASIO4ALL] --> ExtS #2 Ch.3/4 --> Physical headphones
BORING DAW Instance #1 --> [using ASIO4ALL] --> MULTITRACK Instance #2 --> [using ASIO4ALL] --> ExtS #1 Ch.7/8
BORING DAW Instance #2 Main Out --> [using ExtS #2's own ASIO driver] --> ExtS #2 Ch.1/2 --> [using physical wire] --> ExtS #1 (can hear it by flipping USB / Phono switch, thus toggling between the Reason rack channels & BORING DAW Instance #2 Main Out)
BORING DAW Instance #2 Cue Channel --> [using ExtS #2's own ASIO driver] --> ExtS #2 Ch.3/4 --> Physical headphones
My problem:
This setup is very crashy & jittery when play is pressed in one DAW rather than another DAW.
I ABSOLUTELY NEED to hear audio from another DAW in ExtS #1 Ch.3/4 + Ch.5/6. This audio needs to come from ANOTHER DAW NOT MENTIONED HERE. This is the biggest problem for me - ExtS #1 is already in use (heavy use, at that) by MULTITRACK Instance #1 *and* Instance #2. Therefore l cannot use ASIO.
Can Voicemeeter help? If so, please could you give me a clear idea of how to proceed? Please could you explain like you are trying to teach a cat!
Also, if you need further clarification on something, please ask.
turd_rotisserie
Re: Can Voicemeeter Help with Complex Setup?
Vincent, please help, if you need a diagram l can draw one. I really need a solution buddy. I've been working on this on and off for over a year, it's taken me that long to figure out it has no chance of working ... unless, maybe, your software can help?
Also please tell me how l can change my screen name.
well, i would say fisrt that you usually do not need to use ASIO4ALL ...
your DAW can be connected to Voicemeeter Virtual ASIO driver as well...
Directly
turd_rotisserie
Right, so please can you show me how to do this with Voicemeeter. ASIO4ALL has failed me, l am looking to Voicemeeter now, not ASIO4ALL.
just select Voicemeeter ASIO device in your DAW Audio Settings.
turd_rotisserie
Hi, which version of Voicemeeter should l use? Banana? Audio Cable? Mixer?
turd_rotisserie
Vincent, if you take a look at the setup, you'll see that MULTITRACK Instance #1 uses 2 different external soundcard (ExtS #1 & ExtS #2).
I don't see any way around this other than an ASIO driver wrapper, but when l bring ASIO4ALL back into the equation, l'm in trouble all over again.
Please can you show me how to do this so that ExtS #1 Ch.3/4 + Ch.5/6 are left free for use by yet another DAW?
At present, l almost got the setup to work, but on ExtS #1, Ch. 1/2 ended up treated as 1 mono channel, with Ch. 3/4 as the other mono channel in a stereo pair. How that happened l have no idea.
I'll give you $20 if you can make this work with Voicemeeter.
turd_rotisserie
To the eerily silent multitude of people wanting to help me out with this:
This request is now on hold - l believe the problem may be ExtS #1, which is both a MIDI controller and a soundcard, and probably a dishonest soundcard at that - it says it can give me 4 audio i/o channels, when l suspect really it can only ever give me 2 stereo pairs simultaneously via ASIO.
I had planned for BORING DAW to use 2 stereo pairs itself, and my issue was l couldn't get those 2 channels to BORING DAW, because the setup prior to that had used everything that was available up.
There were still 2 stereo pairs remaining on ExtS #1, but as l suspect: those 2 stereo pairs aren't available if the other 2 pairs are already in use.
HOWEVER overeating can partly compensate for this impasse, soooo l'll go check the fridge now. Au revoir :)
sorry but i don't understand your problem i guess... seems to be a problem of channel management on ASIO driver ?
just explain the minimal rational of your problem (less than 3 lines), and post a screen shot if needed.
