Midi Mapping channel outputs
I noticed in the midi options that output selectors were not available. I have a launchpad mini and i was wondering if support for switching outputs will be available. IE. using midi buttons to select A1,A2,A3... for each hardware input and virtual input?
Re: Midi Mapping channel outputs
yes, right BUS Assignation button are not in the MIDI map.
it's maybe better to use MacroButton and make the assignation function you want,
possibly activated by a MIDI command
Vincent Burel wrote:yes, right BUS Assignation button are not in the MIDI map.
Do you plan on adding these as toggle-able midi buttons?
I love your software, and this would be a great addition.
