DAW to VMB
rboss
DAW to VMB
Post by rboss »
Complete newb here.....is there any way possible to output audio from say Reaper to Voicemeeter Banana and then from VMB to Audition?
Basically wondering if I have a 4 input 4 output interface could I input that into one DAW then have it come through VMB to the other DAW.
Or....a simpler way to ask....is there anyway to combine 4 outputs of an interface into 1 channel in VMB?
Re: DAW to VMB
yes, Voicemeeter provides virtual ASIO input as well to connect up to 4 DAW .
please read user manual for more informations page 13:
rboss
Re: DAW to VMB
Post by rboss »
Also...when using ReaRoute, the ReaRoute Asio doesn't show up in the hardware outputs.
Re: DAW to VMB
Maybe because only ReaRoute 64bits ASIO driver is installed... check with your provider, if you can install 32bit ASIO interface too.
(Voicemeeter , as 32bits application, will list 32 bits ASIO interface only - but audio device manufacturers are expected to install both interfaces on 64 bits O/S : 32bit & 64 bits ASIO DLL).
