Voicemeeter does not uninstall.
turd_rotisserie
Post by turd_rotisserie »
Voicemeeter keeps starting when l try to uninstall it from Control Panel, or tells me to wait for it to shut down before l press the button to uninstall it again, which in turn inevitably starts it up again.
I just want to uninstall it.
Last edited by turd_rotisserie on Wed Oct 10, 2018 9:13 am, edited 1 time in total.
Re: Voicemeeter keeps starting when l try to uninstall it from Control Panel
you may read this topic: viewtopic.php?f=6&t=381
turd_rotisserie
I've already tried the suggestions in that topic.
I've tried all of the suggestions available.
There is no formal way to uninstall this program, because upon uninstall, Voicemeeter starts up.
There are many programs available to download, for example accountancy software and strange audio software.
One thing they have in common is that you can uninstall them, and if uninstall isn't one-press via control panel, then you can ask the program directly to uninstall itself.
Yours is the one exception. It doesn't uninstall. Why?
Re: Voicemeeter does not uninstall.
again, the installer is checking if the voicemeeter virtual audio drivers (VAIO's) are installed or not
if it remains some part of the voicemeeter virtual audio driver on the system, it will consider that voicemeeter is still installed.
so, go in device manager and de-install manually Voicemeeter virtual audio controller or I/O (there is categories of driver to check) and Reboot until having nothing there anymore...
REM: YOU GET THIS PROBLEM BECAUSE YOU FORGOT TO REBOOT after Installation or De-Installation.
