I am a ham radio operator and daily use VBCable to link my software defined radio (Flex SDR-1000) to a variety of ham radio processing applications. Worked perfectly and only need a single a single VB cable. Please note that bi-directional audio used between all the various applications.
However, I now have the need to inject the audio from a physical or usb sound card into the VBCable data stream.
What is the easiest way to accomplish this.
Thank you.
Don
Inserting Sound Card or USB Audio into VBCable
djarvis
Re: Inserting Sound Card or USB Audio into VBCable
Voicemeeter.
djarvis
Vincent,
Is it better to connect a VBCable into one of the regular input channels or the VAIO virtual input?
Same question for the output back into the VBCable. Regular output or digital output?
Does using Voicemeter or VM Banana make any difference?
Thank you,
Don
Thank you,
Don
