Voicemeeter using two USB SoundCards set to 44.1KHz with slight ppm
Aman101
Re: Voicemeeter using two USB SoundCards set to 44.1KHz with slight ppm
Postby Aman101 » Wed Dec 19, 2018 2:04 pm
Assuming A1 and A2 are both connected through an asynchronously USB interface, they will have different clock domains.
Assuming A2 has a slightly higher clock rate (by a few PPMs), PC will have to sync them otherwise there will come a time A2 will not have Audio data to output.
How do you solve that problem? Sample-Rate Conversion?
Postby Vincent Burel » Wed Dec 19, 2018 3:04 pm
The problem is solved by Voicemeeter, designed to work with any audio clock on any audio point.
Aman101
Postby Aman101 » Wed Dec 26, 2018 12:17 pm
Thank You.
Return to “Voicemeeter”
Users browsing this forum: No registered users and 7 guests
