Remote Voicemeeter Potato macro button bypass ext fx MPX1
Posted: Thu Dec 13, 2018 4:45 pm
by mipsou
I use the MPX1 as an external effect.
It is linked with the external effect fx1 of potato on my main PC.
I would like from my encoding PC dedicated to the stream remote control with the stream deck via a macro for the bypass of the external effect fx1 (Directly point Voicemeter Potato or the MPX1 through the VBAN2MIDI)
The contents of the activated macro could be
External_FX[1].Volume = 10
Toggle.B1 = off
Toggle.B2 = off
Or send MIDI ControlChange via VBAN2MIDI
Does anyone have an idea to create this macro?
Regards
Re: Remote Voicemeeter Potato macro button bypass ext fx MPX1
Posted: Mon Dec 17, 2018 4:21 pm
by mipsou
I answer myself:
I use this macro in the following context. It's for a live stream performance system. I activate the MPx1 fx on demand for voice announcements.
Initial State
System.SendMidi("out1", "prg-change", 3, 1);
System.SendMidi("out1", "ctrl-change", 3, 84, 0);
BEGIN_SECTION("vban1")
Strip(0).fx1=0;
Strip(0).B1=1;
Strip(0).B2=1;
END_SECTION
Button On
System.SendMidi("out1", "prg-change", 3, 2);
System.SendMidi("out1", "ctrl-change", 3, 84, 0); //Bypass On CC84
Strip(0).B1=0;
Strip(0).B2=0;
Strip(0).fx1=10;
END_SECTION
Button Off
System.SendMidi("out1", "ctrl-change", 3, 84, 127); //Bypass On CC84
Strip(0).fx1=0;
Strip(0).B1=1;
Strip(0).B2=1;
END_SECTION
With this macro, you control remotely your's external fx by midi and route one strip with a single button Dtream Deck.
Good luck and have a fun
