Output stuck at 8000hz
llaffer
Re: Output stuck at 8000hz
Post by llaffer »
Vincent Burel wrote:As we explained, this is concerning recording devices, not playback devices.
so you may check the default format used by the cable output (not the input).
OK. The images I posted in the previous question were from the playback devices.
Doing the same to the Recording devices they are set to 8000. I will set them to 44k and try a test to see if that helps.
Thanks.
