[Potato] How to use and monitor reverb
neilj99
Postby neilj99 » Sun Dec 23, 2018 7:24 pm
I’m currently trying Potato.
I haven’t figured out how to monitor the internal reverb effects via my headset.
I’d like to add a spot effect to my mic.
I’m using VM and streaming on the same system.
How do I get the effects to work?
Thanks.
Neil.
Re: [Potato] How to use and monitor reverb
Postby Vincent Burel » Sun Dec 23, 2018 8:32 pm
simply set the REVERB SEND to max (10.0) on your microphone strip
and set the REVERB RETURN to max (10.0) on the wanted BUS.
neilj99
Postby neilj99 » Sun Dec 23, 2018 8:37 pm
Many thanks.
I’ll give it a go.
Absolutely love the software.
Neil
P.S. Whilst I think of it, is there a way to assign a keyboard hotkey to toggle the effect?
Postby Vincent Burel » Mon Dec 24, 2018 7:19 am
for the moment the following new instructions are implemented:
Strip[i].Reverb 0 to 10 Send Level To Reverb
Strip[i].Delay 0 to 10 Send Level To Delay
Strip[i].Fx1 0 to 10 Send Level To External Fx1
Strip[i].Fx2 0 to 10 Send Level To External Fx2
Strip[i].PostReverb 0 (off) or 1 (on) Post Reverb button
Strip[i].PostDelay 0 (off) or 1 (on) Post Delay button
Strip[i].PostFx1 0 (off) or 1 (on) Post Fx1 button
Strip[i].PostFx2 0 (off) or 1 (on) Post Fx2 button
Bus[i].Sel 0 (off) or 1 (on) BUS SEL Button
Bus[i].ReturnReverb 0 to 10 Reverb return
Bus[i].ReturnDelay 0 to 10 Delay return
Bus[i].ReturnFx1 0 to 10 FX1 return
Bus[i].ReturnFx2 0 to 10 FX2 return
neilj99
Postby neilj99 » Mon Dec 24, 2018 1:53 pm
Apologies.
I was just wondering how to assign a keyboard keystroke to the effect.
The above has confused me slightly.
N.
Postby Vincent Burel » Tue Dec 25, 2018 10:44 am
with MacroButtons
neilj99
Postby neilj99 » Thu Dec 27, 2018 7:48 pm
I can't get the reverb to come through OBS.
I have A1 set as my headset.
I have strip 1 set as Cabel A - Mic >A1 >B1
I have strip 2 set as Cabe B - TTS >A1 local only
I have strip 6 set as Mic VM VAIO >A1 >B2
I have strip 7 set as System Audio VM AUX >B2
I would like to hear the reverb and send it to OBS (Cable A Output at OBS).
Thanks,
N.
JBP
Postby JBP » Fri Dec 28, 2018 12:03 am
It is important to understand that all the virtual B-busses (B1, B2, B3) represent VAIO not related to VB Cables.
If you want to use VB Cable-A as input (Cable-A Output) in OBS then you have to select Cable-A Input as a hardware out (A1, A2, A3, A4, A5) in Potato!
Then you adjust the FX return for that specific output.
neilj99
Postby neilj99 » Fri Dec 28, 2018 3:26 pm
If I select Cable A Input as A2 (A1 is my headset), then Audition fails, as in Audition, I have my mic as input and Cable A Input as output. I EQ my mic through Audition.
I seem to be getting nowhere fast.
N.
JBP
Postby JBP » Fri Dec 28, 2018 3:44 pm
neilj99 wrote:Hi,
N.
If you have Cable A then you also have Cable B and the standard Cable.
So you have this three (3!) Cables and A1 plus four other outputs (A2 to A5) you can use with all Cables:
VB Cable + VB Cable A + VB Cable B :!:
Return to “Voicemeeter”
