Page 1 of 2
Audio Issues While Streaming
Posted: Mon Dec 24, 2018 9:53 am
by stealth1192
So I have a dual streaming setup for streaming and I use Voicemeeter Potato 3.0.0.4 to make the audio go from one PC to the other and make the program be able to capture the elgato audio with no problem. I had this same setup for a long time and now starting to have issues.
https://clips.twitch.tv/PluckyVenomousB ... ingerPower there's the link to how my audio sounds after 2hrs of streaming.
I will attach the settings that I have for both pcs vban and audio setup.
Gaming PC
Voicemeeter Potato Gaming PC.jpg (203.2 KiB) Viewed 17924 times
Voicemeeter Potato Gaming PC VBAN.jpg (204.08 KiB) Viewed 17924 times
Re: Audio Issues While Streaming
Posted: Mon Dec 24, 2018 9:54 am
by stealth1192
Streaming PC
Voicemeeter Potato Streaming PC.jpg (201.2 KiB) Viewed 17923 times
Voicemeeter Potato Streaming PC VBAN.jpg (195.44 KiB) Viewed 17923 times
If you have a solution please share :(. This is preventing me from streaming at the moment.
Posted: Mon Dec 24, 2018 11:25 am
it sounds like a feedback loop on your game sound or discontinued stream on your game sound.
so to help you, you may describve the audio path for your game sound:
from the game to the recording or the monitoring point where you can hear the problem.
(REM your IP might not be hidden if you want me to check something o your VABN configuration).
the Voicemeeter System Settings Dialog Box screenshot can also help...
Posted: Mon Dec 24, 2018 2:25 pm
by stealth1192
This is the audio where most of the game sound is going through is this is what you mean
Where the game sound is going through.jpg (161.93 KiB) Viewed 17919 times
These are the systems settings
Gaming PC
system settings PC.jpg (155.69 KiB) Viewed 17919 times
Streaming PC
system settings streaming PC.jpg (154.45 KiB) Viewed 17919 times
by stealth1192
VBAN Settings showing IP
Gaming PC
Voicemeeter Potato Gaming PC VBAN.jpg (204.08 KiB) Viewed 17919 times
Streaming PC
Voicemeeter Potato Streaming PC VBAN.jpg (195.44 KiB) Viewed 17919 times
Posted: Mon Dec 24, 2018 2:26 pm
by stealth1192
The weird part is only my stream hears it. I never hear it at all.
Posted: Wed Dec 26, 2018 2:53 am
by stealth1192
Is this enough information to help with my problem or no?
Posted: Wed Dec 26, 2018 8:45 am
i need to know what is the signal path.
audio source is coming in on what voicemeeter , what input ?
your stream get audio from what voicemeeter , what output ?
Posted: Wed Dec 26, 2018 9:34 am
by stealth1192
I don't understand the question.
My guess to the answer of the question is the input audio is The Gaming PC from the elgato which is also from the consoles when they are in use, Voicemeeter VAIO. The Streaming PC is also putting out audio from its Voicemeeter VAIO input. VIrtual Cable which is the music and Cable-A which I'm using for communication programs.
The stream is getting audio from voicemeeter VAIO on the gaming PC. From the gaming PC it's getting the Elgato Audio.
The audio the gaming PC is getting from the stream is the main audio (voicemeeter VAIO on stream pc), music (virtual cable), and discord audio (virtual cable - A)
Streaming Software Mixer.jpg (28.93 KiB) Viewed 17901 times
The software is getting audio starting from the top.
- Voicemeeter VAIO
- Mic is the USB Mic
- Virtual Cable - A
- Virtual Cable
- Elgato Capture Audio
Posted: Wed Dec 26, 2018 7:05 pm
by stealth1192
Was what I wrote the answer to your question or no?
