is this easy possible. the easiest to program solution from one of the ideas is ok
I notice when choose in windows sound output voicemeeter input and i have not hook volume keys that when level is 1-99 all is full loud. when level is 0, then all is silent. is it not easy possible to programt hat the Voicemeeter input can use correct volume settings as all other audio cards doo ?
for the hook volume keys feature. i am also happy if you can easy program that when voice meter is iconify and change the volume that voicemeeter mixer is show for 1 sec to see which volume is set. perfect solution is when voicemeeter can show a small popup window for 1 sec and see the volume level and if mute or not.
have a level indicator number is a usefull standard feature all TV soundcards or devices have i see.
[Feature request] volume level indicator display when use hook Volume keys ?
Re: [Feature request] volume level indicator display when use hook Volume keys ?
Windows volume control is not implemented in our VAIO's
if this volume control mute our Virtual Input or Output, it's made by Windows, not by our driver.
If you want to manage VAIOs Volume, use Voicemeeter Slider instead.
we note your request about Voicemeeter Gain Level Display... or miniview...
we rellay neaed this come on Screen Volume Level Indicator
https://www.raymond.cc/blog/useful-tool ... indicator/
