Installing VB Potato
bluemax
Post by bluemax »
Just a quick question for clarification.
Do I need to de-install VB Banana before installing VB Potato, or can I just install Potato over Banana?
Thank you.
JBP
Re: Installing VB Potato
Post by JBP »
bluemax wrote:Do I need to de-install VB Banana before installing VB Potato, or can I just install Potato over Banana?
:arrow: Run Potato setup and follow instructions :!:
Potato automatically reinstalls Banana and standard Voicemeeter!
You will not lose Banana! :)
yes, all Voicemeeter have to be de-installed first... and REBOOT
Then you can install Potato or other and REBOOT after too.
JBP
Post by JBP »
Ok, the REBOOT must be done manually by the user.
But deinstallation/installation process cannot go wrong as long as the user reads the onscreen instructions and does what have to be done (manual REBOOT).
I think that this user was more concerned to lose Banana, when he installs Potato.
So, to all (do not be afraid of Potato): :lol: 8-)
Potato automatically reinstalls Banana and the standard Voicemeeter, too!
bluemax
Post by bluemax »
Thank you.
