Instruction syntax to send VBAN-TXT or VBAM MIDI request
With MacroButtons and other coming application, we tend to unify instruction syntax to send VBAN-TEXT and VBAN-MIDI Request through a simple script (while "vban1", "vban2", etc... are VBAN Stream defined in additional option page).
The current instruction syntax used in MacroButton to send a VBAN-TEXT request is to use a BEGIN_SECTION instruction like this
BEGIN_SECTION("vban1")
Strip(0).mute=1;
Strip(1).mute=1;
Bus(0).gain= 0.0;
END_SECTION
In the future we will also implement the function style syntax like this (also to fit SendMidi function syntax).
SendText("vban1",
Strip(0).mute=1;
Strip(1).mute=1;
Bus(0).gain= 0.0;
The VBAN-MIDI Instruction syntax is defined with function called "SendMidi":
4x M.I.D.I. Request types are defined (channel 1 to 16):
SendMidi("vban1", "note-on", channel, note, velocity);
SendMidi("vban1", "note-off", channel, note, velocity);
SendMidi("vban1", "ctrl-change", channel, ctrl, value);
SendMidi("vban1", "prg-change", channel, nPrg);
There is also a RAW DATA function to send any M.I.D.I. Message (including sys-ex).
SendMidi("vban1", "data", aa, bb , cc, ee, ff, gg, ...);
NOTE: VBAN-MIDI Request can be converted to physical MIDI output through the application VBAN2MIDI.EXE (installed with Voicemeeter)
