startup difficulty
jeffjohn1941
startup difficulty
Post by jeffjohn1941 »
When I wake my Win 10 from sleep. Bluetooth monitor says I am connected to listening device (Roberts Stream), but there's no sound connection. A Win restart does reconnect sound. I did have 'auto-restart' active in menu; is this correct? I inderstand that a startup delay is now incorporated in later versions; would this solve my problem? (currently 2.0.4.4).
Terrific software - I'm thrilled with it - thanks! :D Jeff
jeffjohn1941
Re: startup difficulty
sorry posted on wrong topic area!
yes, the startup delay (5s per default) is there to allow all other services start... before Voicemeeter attempt to use them.
jeffjohn1941
Many thanks for prompt reply. Yes that does seem to be the solution! Regards jeff
