Voicemeeter Potato Virtual Outputs
mikeb206
Post by mikeb206 »
Hi all, new to the forum but have been using Voicemeeter Banana successfully for some time. I recently decided to update to Potato. I have uninstalled and reinstalled it several times, however I only ever have two virtual outputs - 'Voicemeeter Aux Output' and 'Voicemeeter VAIO3 Output'. I have those (with input instead of output) and 'Voicemeeter Input' as virtual inputs. Is this normal?
Re: Voicemeeter Potato Virtual Outputs
no, it means the installation process failed...
so you may de-install it and REBOOT.
then check there is no voicemeeter audio device present in the system
follow instruction there: viewtopic.php?f=7&t=688
mikeb206
Post by mikeb206 »
Hi Vincent, I have followed exactly as you described (and was doing the reboot post uninstall with VM and all three cables previously). However, I do not have any residual components in Device Manager, and still only have the same two virtual outputs Image Image
potato package version ? 3.0.0.7 ?
mikeb206
Post by mikeb206 »
Apologies, I should have mentioned earlier that yes I am indeed running potato version 3.0.0.7
could you post screenshot of you playback device list (windows / Sound Dialog box).
mikeb206
Post by mikeb206 »
Here are my playback devices (the Img function doesn't seem to work for me for some reason);
https://ibb.co/pjmfcbj
https://ibb.co/QrCkd3V
And, recording devices;
https://ibb.co/CztgXX9
https://ibb.co/YcDywx9
seems you are missing the Voicemeeter VAIO Recording device.
you may re-install Voicemeeter Potato Package...
1- first de-install + REBOOT + cehck there is no Voicemeeter device present in Windows Device Manager:
2- Re-install Voicemeeter Pototo + Reboot.
