I've been using Banana sucessfully for a while now, ready to switch to potato to take advantage of some of the new features and extra inputs
I use the Insert Virtual VAIO in another program called Live Professor so I can use VST plugins to process things as needed(compression/eq/gates/fx/etc.)
when I load up potato, I can still see the inserts, but It doesnt give me the aux sends to the software?
(I want to use it for effects sends to some reverb or some tap temp delay - same as anybody would do with an Analog Mixer in the real world)
is it a separate virtual IO or is it just not in the software yet?
Part 2 of the question would be, can it be made to go to the same IO as the insert stuff please so it can be used in the same host program that the inserts are being used with. host programs will only allow one instance of itself, and will only allow 1 of the virtual asio card to be used at a time
potato aux sends - no virtual send to External Program?
s2h
