Voicemeeter - Mic Problems/ Crackling sound / Stutter
Azp3ct-
Re: Voicemeeter - Mic Problems/ Crackling sound / Stutter
Post by Azp3ct- »
No one who can help.....?
ok, i see a possible audio conflict
you use your ASIO device as output A1 (with 512 sample buffer) = good!
but you also selected MG-XU Line in as harsdware input #1 : this is a conflict, because you ask for WDM access to an audio driver already accessed with ASIO interface.
to use your ASIO device input directly in Voicemeeter :
you may select nothing as hardware input...
and possibly use ASIO patch to route ASIO input in Voicemeeter strip
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:ok, i see a possible audio conflict
Well i have a Mixer Yamaha mg10xu and my Microphone is in the Mixer Same as my Headphones, if i dont select any input device as microphone i cant use it in Voicemeeter right ?
if you have selected your Yamaha mg10xu ASIO driver as output A1
you normally should not have to select it as WDM device for your microphone...
because the ASIO PATCH can do it for you directly in a better way.
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:if you have selected your Yamaha mg10xu ASIO driver as output A1
ok so i have those settings set now, and in Windows Sound settings in looks like this
https://imgur.com/a/OgQkeIx <--------- Playback Device
https://imgur.com/a/PZ8DZaS <--------- Recording Device
https://imgur.com/a/gFnUeZ8 <--------- Voicemeeter Settings
This is how i set it up, is this correct ?
thank you for your help !
Azp3ct-
Post by Azp3ct- »
Since a few Days, again Distorded Sound and Crackling Sounds appears in Voicemeeter Potato. Why is that and how can we fix this ? Is there a Problem with the Programm because i cant Use discord or Shadowplay anymore.
If i Use my Line in Mic as Source without Voicemeeter its sounds Normal, using it with Voicemeeter making crackling sound and Distorded.
Playback Settings
https://gyazo.com/1a7f6ce961a56cc4d4ca08a952a388cc
Input
https://gyazo.com/38d05947e4bb25078dd89bd47d715bad
Voicemeeter Potato
https://gyazo.com/fd6ec8de08694cbbbaeeef2658453f6e
https://gyazo.com/27250dc8b9715f5eb0751c38ffd15ba8
i really need help because iam streaming atm and to the Goal of 4k Followers i dont want to lose this software. because it is so nice. Really need help
Azp3ct-
Post by Azp3ct- »
Additional Source and Video
https://www.youtube.com/watch?v=shNW2c3 ... e=youtu.be
https://gyazo.com/86082f12dc285fff888940f539eefb8e
https://gyazo.com/cc5eebd07660de6d18f6774ff7e11bd6
Azp3ct-
Post by Azp3ct- »
Help ?
if you have problem on VB-CABLE connections (PATH), please check the related VB-CABLE internal latency (must be 7168 sample per default).
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:if you have problem on VB-CABLE connections (PATH), please check the related VB-CABLE internal latency (must be 7168 sample per default).
All of the Virtualcables which are installed are 7168 Sample rate
