*BUG FIXED* Potato Master Selection A5 Bug
geekgarage
without any master selection set, i set A1-5 and B1-3 to 0. I set all inputs to 0db. Then i select my first input as my USB mic and set output to A1-5 and B1-3
I then go through each master selection and when i get to A4 and adjust input on the mic it adjust the output on A4 as expected but also adjust output for A5. When setting master selection to A5 and i adjust the input for my mic nothing happens.
Same thing if i move the input to hardware input line 2. so i guess in the code, master selection for A4 is replicated to A5 instead of A5 having it's own master selection settings
Issue replicated on secondary sytem
geekgarage
Re: *BUG* Potato Master Selection A5 Bug
is there a github i should post this issue on istead?
could you tell your Voicemeeter version ?
i cannot reproduce this problem.
geekgarage
Hi Vincent, my potato version is 3.0.0.7
geekgarage
Here is a video clip of it
https://streamable.com/a5893
ok, thanks for this video, now i got the problem.
it will be corrected in next update.
geekgarage
Any updates on when the next update is as i'm missing the channel
yes, we are expecting to update many things in May...
geekgarage
So any updates as we are now i June?
yes, we are late, but we are on it... sorry for the delay.
