VoiceMeeter MIDI preventing shutdown
TomW1605
Post by TomW1605 »
Hi
I am having an issue when shutting down. my system hangs on the shutdown screen. from the logs in event viewer i think the problem is with my arduino leonardo that i have used to build a midi mixer however i have also noticed that if i shutdown VoiceMeeter or set it to no midi input my system shuts down as normal. i think this might be related to this issue and VoiceMeeter keeping the audio device open.
thanks for any help
Re: VoiceMeeter MIDI preventing shutdown
normally Voicemeeter shutdown too when Windows is shutting down... i guess there is something that lock the process... possibly a driver then.
TomW1605
Post by TomW1605 »
i agree it is a driver issue however it is definatly related to voicemeeter. there are 2 senarios that alow for a propper shutdown
1. unplug the device and leave voicemeeter on
2. leave the device pluged in and exit voicemeeter
based on some googaling and this SuperUser question i think that the driver is stoping the shutdown (and automatic sleep but i never use that) because voicemeeter is holding the audio stream open
as per the mentioned SU question i have tryed to override the drivers stopping shutdown but that also hasent worked
2019_04_03 10_09_09.png (53.84 KiB) Viewed 8925 times
i have tryed scripts to close voicemeeter befor shutdown but i cant seem to get that to work. for some reason it does not rlease the driver eaven when shutdown. i think it is the Legacy Kernel Caller driver that is messing up.
TomW1605
Post by TomW1605 »
i have found a 3rd scenario that works
leave the device pluged in and voicemeeter on but unselect the device in the midi mapping screen
