My request is as follows, is there anyway to achieve bus volume independence, as in lets say am playing a game and streaming and listening to music with an app but that app is also sending audio stream, how do i adjust volumes on the 2 lanes I intend to use as output, for example, on my end I might want the music lower than game and in stream have, for example, adjustable levels of mic game and music without affecting my sources of audio going to my headphones, so is this possible in any shape or form in voicemeeter potato.
The idea behind is as follows mic game music audio to be independent of all three so I can adjust whenever needed while keeping my volumes at my desired level while maintaining stream volumes independent on all three channels with the intent that something either in the stream or my end requires change does not affect the other end.
With that, all said I hope to find a way to achieve independence on all the things.
[advice request/question] how to achive 2 buses with diferent volume outputs from some sources in use, details in post
iurirolho
Re: [advice request/question] how to achive 2 buses with diferent volume outputs from some sources in use, details in po
there is a multi layer mixer on Voicemeeter Potato
SEL button on each BUS allows you to define an independent mix
