Stereo Repeat only for stereo sources
stenyak
Post by stenyak »
Hi all, VoiceMeeter noob here, started using it a few days ago.
I was wondering if there's any way to use the stereo-repeat mode only for audio sources that are stereo. E.g. have youtube play on all speakers, then alt-tabbing into a 5.1 movie player that still output its 6 channels independently, without having to manually switch stereo-repeat on/off.
Thanks for any advice (and thanks to the creator for such a nice piece of software!)
stenyak
Re: Stereo Repeat only for stereo sources
Post by stenyak »
Bumping once just in case ("not possible" would be welcome as an answer too :-) )
i don't know if i understand well the question, the BUS mode is set by the user (manually).
stenyak
Post by stenyak »
Vincent Burel wrote:i don't know if i understand well the question, the BUS mode is set by the user (manually).
BUS mode is what I'm resorting to at the moment. The problem is I need to change it each time I use software with different amount of channel outputs.
E.g. sometimes I'm listening to youtube in a browser with 2.0 output (bus mode set to "stereo repeat"). Then I start watching a movie, and then I notice I can hear no voices (because the 2.0 channels are overwriting all other channels, including the center channel). So I have to go switch bus mode back to "normal mode".
In some cases, e.g. Telegram web client voice messages, these play through the center channel only, so the usual "stereo repeat" (that I use while browsing) essentially mutes the voice messages (as it's the empty L and R channels overwriting the voice channel).
My question (or probably request) boils down to: if the virtual output device can detect the amount of channels used by each program that connects to it, then a BUS mode 'speaker fill" would be nice, where the Center-only voice messages spread to all other 5.1 channels; or the L/R-only youtube music spreads to 5.1; or the 5.1 movies stay as-is; or 4.0 movies spread to 5.1, etc. Without having to manually choose the BUS mode for each application, and without losing the channels that do exist (no matter which they are in each particular case).
Thanks for any help!
stenyak
Post by stenyak »
Vincent Burel wrote: Mon May 13, 2019 7:30 pm i don't know if i understand well the question, the BUS mode is set by the user (manually).
Hi again Vincent :)
Just quickly checking if this is possible now.
The TLDR is: ability for stereo apps (like youtube in browser) to use "stereo Repeat", while simultaneously 5.1 apps (like a 5.1 movie player) using "Normal mode". Without having to constantly click the relevant voicemeeter button, each time one goes back and forth between apps.
Thanks!
the BUS mode is located on BUS , not on source (strip).
This option/mode is not planned to be implemented on strip.
stenyak
Post by stenyak »
Vincent Burel wrote: Sun Sep 07, 2025 7:59 am the BUS mode is located on BUS , not on source (strip).
Is there any workaround I could use?
For example, I tried assigning one output device to 2 different buses (one on stereo repeat, the other on normal mode). Then I planned to assign each app to the appropriate bus.
But I can only use each output device on a single bus at a time.
the only way to do what you want is to implement these 5.1/7.1 mode on multichannel strip. i note it for next update or next generation mixer.
stenyak
Post by stenyak »
Vincent Burel wrote: Mon Sep 08, 2025 1:44 pm the only way to do what you want is to implement these 5.1/7.1 mode on multichannel strip. i note it for next update or next generation mixer.
That would be great. Thank you, I appreciate it!
