[Suggestion] Labels for Virtual Outputs
djanim8
Post by djanim8 »
I think it would be helpful to have labels for the "B" virtual outputs like the virtual inputs and have it be displayed on the fader or maybe when the mouse hovers over the slider knob. I have mine set but don't use them all the time and forget which ones I have set for which programs. Just a thought.
Re: [Suggestion] Labels for Virtual Outputs
you can enter a label on output slider by on CTL+Right Click on bottom of the slider.
