Macro functions without buttons being open?
Posted: Sun May 26, 2019 1:53 am
by exigeous
Is there a way for macros to work without the button "app" being open? I only very rarely use a couple macros so it drives me nuts that I have to have this one little app open on my taskbar just for the rare times I use that. Is there a setting so they will work, via hotkeys, just from the main app running (and in the system tray)?
Re: Macro functions without buttons being open?
Posted: Sun May 26, 2019 5:33 pm
by hdpcshow
You could drag the icon on the arrow so that you don't see it.
https://u.teknik.io/nYcNY.mp4
Posted: Sun May 26, 2019 11:53 pm
by exigeous
Thanks for the reply - appreciated - but that's not what I'm asking, although it's perhaps close. My issue isn't the system tray, it's the taskbar - I have the app (Banana or Potato) set to minimize to the task try when I click the X but the "button" app doesn't seem to work that way - that said I see in your video (great that you did that, again thanks) you are able to minimize the "buttons" to a task try icon - I see no way to do that. So it just sits on the taskbar like this
https://imgur.com/KM3Xk6k
What am I missing??
Posted: Tue May 28, 2019 2:24 am
by hdpcshow
Yea your right i forgot to tell. Left click on the top bar. And enable "System Tray"
https://i.imgur.com/145GHLQ.png
Posted: Tue May 28, 2019 1:37 pm
by exigeous
YOU ARE MY HERO!!!
Seriously, BIG THANKS as that's been driving me crazy forever! As much as I love Voice Meeter it's interface really does leave a lot to be desired.
~Exigeous
