Audio crackling / static / breaking up
Posted: Mon May 27, 2019 10:25 am
Hi -
Could anyone help, please? Although I can see similar questions have been asked frequently on this board before, I could really do with a pointer as to where to start to get the problem sorted out once and for all.
I've set up a basic all-ASIO audio chain with Voicemeeter Banana 2.0.4.7. A1 is a Focusrite USB interface; channels 1 and 2 of that are being processed with an application connected to the Voicemeeter Insert ASIO driver; and the audio is being sent to both B1 and B2, with two other applications receiving the audio data at the other end of the Vaio and Aux ASIO drivers. The machine running this is a dedicated, clean Core i5 box running Windows 10 and with more than enough processing headroom.
Here's the setup in Voicemeeter:
Randomly, the audio received by at least one of the end applications at B1 or B2 crackles. Sometimes one, sometimes both, or sometimes neither. It's always right from when they first start up - when they work, they'll work indefinitely. Sometimes switching them from Vaio to Aux or Aux to Vaio fixes the problem. Occasionally the crackling will be received by the application connected to the patch insert, but this hasn't happened for a while. Restarting the audio engine in Voicemeeter doesn't help.
Here's an example:
https://vocaroo.com/i/s1eXtoCO9Z4z
What can I do to sort this out? I've seen that there are problems with the Focusrite ASIO driver - is that's what causing this?
Thanks
Here's an example:
Thanks
