VB-cable not working when launching Team fortress 2
hdpcshow
Post by hdpcshow »
I use VB-cable as a 4 virtual cable(i have potato) in this case for game audio. When i launch team fortress 2 the audio doesn't work only when i select a different audio device and select it again. PS:You have to click on something in game so the audio will go through.
https://i.imgur.com/OJd0I2J.png
I use Windows 10 Pro
PSS: This doesn't happen with the virtual cables from VoiceMeeter Potato.
Re: VB-cable not working when launching Team fortress 2
this cable input is maybe used by another app in exclusive mode ?
hdpcshow
Post by hdpcshow »
Vincent Burel wrote:this cable input is maybe used by another app in exclusive mode ?
There is no other program using the cable. I did turn of the exclusive mode(input and output) but that didn't change anything. From the other drivers this cable is having a pull lose when nothing is going through and in this case when Team fortress 2 is running seen in the control panel.
https://i.imgur.com/2nTdQrV.png
Tested Warframe and Outdrive both run fine with the driver.
maybe the internal latency is not big enough for this game, if using too much big buffer...
hdpcshow
Post by hdpcshow »
Vincent Burel wrote:maybe the internal latency is not big enough for this game, if using too much big buffer...
i tried to change that but it has no effect. I found out that when i used default device on any of them vb cables it works but it just doesn't work when i used the Windows App volume and devices preferences on all the virtual cables. Changing latency or exclusive mode didn't do anything.
did you try the last Voicemeeter VAIO's instead.
they can offer to increase internal latency to 16384 or even 32k ... but usually 16384 could work...
hdpcshow
Post by hdpcshow »
Vincent Burel wrote:did you try the last Voicemeeter VAIO's instead.
I tried all of them (so many reboots oof) but still nothing.
don't understand, you may ask to Team Fortress 2 support so...
you may read this topic too:
viewtopic.php?f=6&t=796
