Rear Speakers 5.1 Surround Sound
LoneStar
Postby LoneStar » Fri Jul 12, 2019 5:03 pm
Cannot get sound from rear speakers 5.1 Surround Sound. I've configured Speaker Setup in Sound Control Panel for Voicemeeter Input also Voicemeeter Aux Input. I've tried 5.1 and 7.1 setup. When I perform speaker test each speaker moves the sound bar in the Physical and Virtual Master Section. The speaker test also shows activity in the Input Levels of each speaker in Output Driver info section of VB-Audio Virtual Cable Control Panel. When I try a 5.1 Surround Sound test or play music, I only get sound for the front left and right and center speakers.
Voicemeeter Input is set to Default Device and Voicemeeter Aux Input is set to Default Communication device. The Voicemeeter Master Section is set to Normal mode. I everything in the Playback Sound Control Panel set to 16bits, 44100 Hz.
Is there something I've missed or doing wrong? Let me know if you need additional information.
Thanks
Return to “Voicemeeter”
