VM Potato Mixer Selection and Macros
vootsby
Post by vootsby »
Hi. I'm trying to do some simple level adjustment macros involving mixer selection states and I'm not sure if I'm missing something or if there's a feature request here.
The illustrative example is a Mic On/Off button. My setup is:
* Input 1 - Mic
* Input 2 - Music via VB-Cable
* A1 -> Speakers
* B2 -> Stream
I have the music volume set to different levels for A1 and B2 via Sel. When I use my macro button I want the following to happen:
Mic On:
* Mute A1
* Fade Music on B2 only to a specific level.
* Unmute the Mic input
Mic Off:
* Mute Mic input
* Fade Music back to original level on B2
* Unmute A1
Everything works fine apart from the fading, which appears to ignore the selection states at the point the fade request is made. So this ends up fading the music volume level to -9 across all outputs:
bus[0].mute=1;
bus[6].sel=1;
Strip(1).FadeTo = (-9.0, 500);
bus[6].sel=0;
strip[0].mute=0;
I can fudge the function by using selection state and setting gain directly to fix the values after the fade but is there a better way? If not, could I request this for some point in the future?
Re: VM Potato Mixer Selection and Macros
yes, we see the problem, but no solution for the moment.
