I am running Voicemeeter Banana on my machine and just encountered a Windows BSOD. On the analysis of the memory dump, I found that Voicemeeter was the cause of the error. The error says "The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application." This tells me that nothing critically went wrong but Windows shut down to prevent the possibility of security risks.
I would like to know what settings in Voicemeeter I can change to avoid these overflow errors in the future. BSOD are something I would like to avoid and if there is a better setting config I can use in Voicemeeter to fix this I am up for it.
I will attach the memory dump in addition to a screenshot of my Voicemeeter settings. If you need any more info please let me know.
Thanks,
Phoenex
The Memory Dump is too large for the forum upload, here is a link to a compressed zip of it on my Google Drive. The file is ~1.5GB zipped to ~200MB.
https://drive.google.com/file/d/1bgDuER ... sp=sharing
BSOD from Voicemeeter Banana
Phoenex
- VoicemeeterBananaSettingsSnip.PNG (78.57 KiB) Viewed 10002 times
Re: BSOD from Voicemeeter Banana
Never heard about this error. Stack overflow are usually reproductibles and are producing a regular crash.
in your case, it sounds more like a system problem or viral infection:
https://answers.microsoft.com/en-us/win ... 591ea34cac
Next time BSOD happens, just provide the last minidump (in Windows / Minidump folder).
