Need helps streaming from daw to mobile devices
Flamingon
Post by Flamingon »
Greeting CN-Audio forum!
I'm new and looking for helps,
So I'm using studio one 4 as the daw, tc konnekt 48 as audio interface.
I'm looking for a way to stream the audio from my master bus to my android phone. So far, I've successfully stream audio from YouTube and other sources to my phone. However, I can't stream audio from my output 1-2 which is my main monitors.
Please help me with the configuration, thank you and sorry for my English.
Re: Need helps streaming from daw to mobile devices
you can VBAN Stream from Voicemeeter output BUS only... so your physical output 1-2 should pass through Voicemeeter.
Flamingon
Post by Flamingon »
Vincent Burel wrote:you can VBAN Stream from Voicemeeter output BUS only... so your physical output 1-2 should pass through Voicemeeter.
Hi and thank you for the response! I'm sorry but does that mean it's not possible to stream from physical output?
If so can you instruct me further?
Thank you.
