[potato + buttons(mobile and pc)] how to setup volume macro buttons
iurirolho
I would like to have 2 button per fader for all my faders so I can go up in volume or down, is this possible to use macro buttons on mobile to do so and maybe the normal one using a controler, if not i will make normal binds instead, if not what's the best way I could setup 2 button per fader
iurirolho
Re: [potato + buttons(mobile and pc)] how to setup volume macro buttons
Ok I think I will 16 new buttons, does macro buttons support wierd macros like numpad + and then a number on numpad, if not what combos can I choose
in your case you may use a MIDI Controller instead...
otherwise you could use SHIFT+1 to increase, and CTRL+1 to decrease strp 1 for example...
iurirolho
I got a app in my phone that runs a app called touch daw I might try and see what happens if it does anything to voicemeeter
iurirolho
It does input midi and recieve so maybe I can use it
iurirolho
Ok found this the app I want to use supports midi using Mackie protocol http://www.jjlee.com/qlab/Mackie%2520Co ... 520Map.pdf so maybe using this pdf I can config voice meeter with it
to setup the MIDI mapping in Voicemeeter you just have to push the LEARN button while you are touching the button/knok/slider on your controller device.
iurirolho
Yester I managed to setup it yesterday
