I think my A1 Main device bitrate is somehow stuck at 16? Or do I misunderstand what the system settings window is showing me?
All of my devices are set to 24 bitrate / 44100 hz via the sound panels. Or does the r:16 in the image not mean what I think?
If it is bitrate 16, how can I fix it to be 24?
Bitrate of OUT A1 Main Device 16, won't change to 24
rivenwyrm
- vb_question.png (72.1 KiB) Viewed 10582 times
wizzard102
Re: Bitrate of OUT A1 Main Device 16, won't change to 24
looks to me like you limited the buffer rate to much and it cant run 24
set your buffer back to 512 on the wdm
i personlly do not run wdm i run mme @ 1024
my Vaio's are at 48000 24bit 7168 buffer rate on their respective control panels
and inside Voicemeeter i run everything MME: 1024 buffer rate
ASIO is 1024
ASIO SR: 48000
ASIO is 1024
ASIO SR: 48000
you may install latest version 2.0.4.8 first...
then check if the problem is still there.
rivenwyrm
Well, just resetting the buffers wasn't enough but between doing that and upgrading to 2.0.4.8, the problem seems resolved. Thanks!
