I am using a Behringer Xenyx Q1202USB 12 channel with Voicemeeter potato.
I can get ASIO input of channel 1 and 2 (stereo) in IN1 but I cannot get ASIO input 3-4 in IN2.
I did put ASIO 3 and 4 in input 2 but the ASIO driver of my mixer is showing 2x as IN and OUT.
How do I get this working? I have also purchased Cable ABCD which show as 8x input in the ASIO driver.
I am using ASIO4ALL.
How do get individual ASIO input?
Re: How do get individual ASIO input?
could you post a screenshot of Voicemeeter System Settings Dialog box ?
the ASIO Patch should allow you to route your ASIO input in Voicemeeter hardware inputs...
Here is a screenshot of my settings:
No mather what I do, all the mixers input goes to Input 1.
See the Asio settings it show 2ch instead of 8 for my mixer.
I would like to patch ASIO input of the mixer to each virtual input A-B-C-D
first, it is not recommended to select ASIO4ALL as output A1. it's usually a useles layer.
or you connect your output A1 directly to a try ASIO driver, or to your windows device.
apparently the ASIO4ALL is providing 2 channels only in yoru configuration.
anyway the PATCH ASIO input strip allows you to route for example
the ASIO channel 1 in Voicemeeter physical input #1 and the ASIO channel 2 in the Voicemeeter physical input #2
Re: How do get individual ASIO input? SOLVED
https://community.musictribe.com/t5/Rec ... d-p/153242
Low end Behringer product just send stereo signal over usb.
I have purchased a Tascam Us-16X08 and I can now see 16 inputs in my ASIO driver.
