Ability to drag and reposition the macro buttons
Posted: Sun Dec 15, 2019 5:48 am
by I3ordo
I wish we could drag and drop buttons
relocate them to new positions to make things more tidy on this panel
Re: Ability to drag and reposition the macro buttons
Posted: Sat Dec 21, 2019 10:52 am
I note your request.
Posted: Thu May 07, 2020 8:50 am
by I3ordo
thank you
Posted: Thu May 07, 2020 9:43 am
by xcasxcursex
Great to see this has been noted. In the meantime OP, here's how you can drag and drop them....sort of.
Export the macro settings to an XML file (Alt+Space ... Save button map). Keep this as a backup, and make a copy to work with.
Open the XML file in a text editor. Drag'n'drop the code for each button.
Save the file when you're done.
Load the settings from the new XML file into macrobuttons app (Alt+space ... Load button map)
It's cumbersome, but not as cumbersome as manually recreating the buttons in the position you want them
Posted: Sat Sep 26, 2020 5:19 pm
by I3ordo
Hi again, i am wondering if any updates about this?
ps: where can we track the changes to VM , a github perhaps?
Posted: Thu Oct 01, 2020 6:28 am
by sjc-or
I'd also like the ability to control their size. I have a lot of them and they take up my full screen and most of the buttons are whitespace with very little text.
Thanks for listening!
Posted: Wed Apr 13, 2022 11:22 am
by I3ordo
sjc-or wrote: ↑Thu Oct 01, 2020 6:28 am
So u mean, the overall size of all buttons right , not individually bigger ones with smaller ones? yeah that d d be great, the latter would be great too
