Voicemeeter banana crash
PainedMushroom
Post by PainedMushroom »
Hello
Voicemeeter somehow crashes or something after my pc wakes from sleep. I am running windows 10
It is not just the engine that needs restarting. I need to run the programmer again before it works.
Is there anything i can do to make it just work after sleep again?
It actually worked when i first installed it, but with engine restart required after sleep.
Re: Voicemeeter banana crash
fisrtly, a crash means the application stop running with a Windows message (or without if frozen).
if you can go in voicemeeter menu and select item like "Restart Audio Engine" this is not a crash.
Coming back from Sleep Mode can generate different problem according audio device used... behavior can be different acording the physical interfaces (HDMI, USB, PCI) or according the driver interface (ASIO, WDM, KS , MME)... But the audio engine Restart should restart the stream, except if you have maybe MME USB recording device connected (as it is explained here: viewtopic.php?f=6&t=430&p=912). Are your using MME interface for a USB recording device ?
PainedMushroom
Okay so i have now enabled the auto audio engine restart to see if that helps.
This is my setup:
This is the error code i can see the log of windows:
Update:
The auto engine restart does not work. The program simply just crashes upon waking from sleep
