When using Voicemeeter Banana 2.0.5.0 with Win10 - 1909.
When restarting Win10 after shutdown it needs the audio engine restarted and sound device restored to Voicemeeter Aux Input (VB-Audio Voicemeeter Aux VAIO)
Before Voicemeeter Banana 2.0.5.0 will function correctly again, Is there a way to fix.
Thank You
Voive Meeter an Windows 10 winver 1909
Clif_Hawk
Re: Voive Meeter an Windows 10 winver 1909
Found My Own Answer.
In Voicemeeter Banana Menu Select " Auto Restart Audio Engine "
Clif_Hawk
2nd Problem
Windows 10 1909 on reboot will switch from Choose you output Device of "VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)" to Speakers.
Is there a way I can stop this auto device Change and allow my choice of output devices to remain "VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)".
no, our VAIOs device name and icon are hardcoded into the driver and reset on Windows STartup. This is made to avoid confusing (everybody must talk about the same things) and to detect bad re-installation made by Win10 udpate...
more info:
viewtopic.php?f=7&t=688
more info:
