ASIO Patch Insert. Option to mute lines when inactive
Posted: Thu Dec 26, 2019 6:59 pm
Could an option to be added for activated patch insert lines to be muted, when there is no DAW connected to the Voicemeeter ASIO insert device?
I am using the insert to add effect and also do gain adjustments to the incoming signal using an external midi device. However when the DAW is not connected for whatever reason, this can lead to very loud sound output, since the unprocessed signal is passed through at full volume by Voicemeeter.
