I'm trying to solve an issue I have with recording audio using the NVidia recording functions (ShadowPlay?) whereby I only want game audio to be recorded, and not some other audio (for example TeamSpeak output). Essentially, all I want to do is feed the TeamSpeak output to a 'virtual' input that isn't seen by NVidia, so isn't recorded. I then want to map this input and all the other Windows audio out to either the monitor speakers or (if connected) the USB headset.
It appears that a combination of VoiceMeeter and Virtual Cable will do this, but I'm not the only user of this PC, so don't want to require my 10 year old to have to understand how the mixer functions work in order to be able to play Roblox!
If I make changes to the routing of various applications and mixer settings etc., are these only applied to my account on the machine, or do they apply to all users of the PC? What I'm hoping is that I can make various customisations to the routing etc., but then when my daughter logs in all audio is just fed straight to either the monitor speakers, or USB headset if it's plugged in.
Thanks
Andy
VoiceMeeter / Cable settings per user?
Re: VoiceMeeter / Cable settings per user?
This you can solve in Shadowplay itself.
Open Shadowplay with Alt+Z
go to Settings -> Audio
Change it to separate tracks:
Actually I realised that if you don't use Voicemeeter you'll record Discord as well though.
So set your Discord to an alternative output (Voicemeeter Aux for example) so that it's not combined with the main/desktop stream.
Like so:
Like so:
Thanks for the response, that's exactly what I'm now doing.
What I was hoping was the the Windows settings for default output were maintained on a 'per-user' basis. However, it appears that they're not.
This just means that after I'm finished, I need to remember to set the default output settings back to going straight to the speakers or headset. That way other users of the PC can just continue as normal.
Thanks for the response.
Andy
Andy
