Multiple ASIO Devices
Posted: Wed Feb 05, 2020 8:40 am
by SSchaffrath
i want to know if there is a possible way, to use 2 or more ASIO Devices in Voicemeeter.
Greetings Sebastian
Re: Multiple ASIO Devices
Posted: Fri Mar 27, 2020 9:15 pm
by AtmanActive
From my understanding and experience, there is no such software that can use multiple ASIO devices simultaneously.
The closest thing to that is ASIO4ALL which can combine several audio devices into one ASIO device, but results are unpredictable.
It could work for your specific situation, but then again, it could not.
Posted: Mon Mar 30, 2020 3:39 pm
In Voicemeeter you can use only one ASIO interface as main stream (output A1).
and use other audio device by using Windows audio interface (WDM, KS MME).
Posted: Tue Oct 06, 2020 11:00 pm
by SSchaffrath
Is there any chance for the near future, that you will work on this topic?
Or do you believe it is even possible to do that?
Posted: Fri Oct 09, 2020 12:38 pm
no, it's possible, we have this technology ready.
but difficult to provide it without a full matrix...
anyway we have such project in stock... will put it on top of the stack
Posted: Fri Oct 09, 2020 9:14 pm
by SSchaffrath
Insane, that is what i wanted to hear
i look forward to trying it out asap when it is out
Thumbs UP
Posted: Tue Apr 26, 2022 11:30 am
by DOCa Cola
Vincent Burel wrote: ↑Fri Oct 09, 2020 12:38 pm
This is an older thread, but the topic is probably still current.
Is this still something that is being worked on or have other things taken priority since then?
Posted: Thu Apr 28, 2022 11:04 am
yes, the VB-Audio matrix is in progress.
