WDM in Output A1 causing robotic, stuttering sound
Posted: Sat Feb 22, 2020 10:08 pm
by migrained
Hi ,
I followed every advice in the forums and tips posted but whenever I use WDM in output A1, I always get a stuttering, robotic sound. I tried increasing the buffer but it doesn't work. The buffer for WDM is at 1056 which is a strange number.
Only MME worked for me in my Output A1.
My output A1 is currently paired with my Grace Design SDAC balanced and it is via USB to my computer.
Here are some screenshots:
Annotation 2020-02-22 125616.png (210.95 KiB) Viewed 9291 times
Any idea what seems to be wrong?
Re: WDM in Output A1 causing robotic, stuttering sound
Posted: Mon Feb 24, 2020 9:49 am
buffer for WDM is at 1056 , usually means your device is running in share mode ('S') and not exclusive mode...
and voicemeeter has possible problem to manage WDM output device in share mode...
SOLUTION: or you may use MME or ASIO device interface... or you may select a device that can run in exclusive mode on output A1
