hello, I finally made the donation of this great software and I liked it but now that I use the VM potato the sound has become robotic and I don't know why, I uninstalled everything and installed it again, I also reset everything and even iso it sounds bad, hatsa sneaks in The sound of the headphones in the microphone, which does not happen with the banana.
if even the same programs do not know why one sounds bad and the other well, do I have to do something else?
Problem with the VM potato, it sounds robotic but the VM banana doesn't
Rexzone
zapoqx
Re: Problem with the VM potato, it sounds robotic but the VM banana doesn't
All sound sounds Robotic? If so, double check settings. You might have an incompatible setup going on unintentionally in Potato as it does not take Banana's settings into account.
if the problem remains, post screenshot of Voicemeeter and its system settings dialog box
recommendation: viewtopic.php?f=6&t=451
