How do I split my mic audio and my desktop audio?
Posted: Sat Mar 14, 2020 6:44 pm
by VoiceSam99
Issue is my mic has comp and gate on, but I dont want it to share the same input as my mic (using Discord). I want the channels for the mic and DAW to be separate.
For Discord, the input is VOICEMEETER Output (VAIO) while the DAW is running on Voicemeeter Virtual ASIO. The DAW in question is FL Studio 20.
Re: How do I split my mic audio and my desktop audio?
Posted: Tue Mar 17, 2020 11:04 am
since you have 2 app connected and want to separate them, you may use Voicemeeter BANANA
if the problem remains, post a screenshot of Voicemeeter to let us see your configuration.
