How do i get ASIO settings to show up?
angusrohan
Post by angusrohan »
I'm trying to figure out how to use ASIO on voice meeter. I've seen from ohter screen shots and users that they have ASIO settings 1-8 in output but I just can't figure out how to make that happen for myself. Any help?
Also, cannot get ASIO options in input either.
Re: How do i get ASIO settings to show up?
you can connect an ASIO driver only on output A1
if there is no ASIO driver in the list, it means you have no ASIO device, or that the ASIO 32bit interface is not installed.
Using Voicemeeter virtual ASIO driver can be done by connecting other applications (Voicemeeter won't propose you to connect to its own virtual ASIO driver).
more info about ASIO in user manual page 22:
using voicemeeter virtual ASIO interface is explained on page 14
