What are all those INPUTS and Outputs?
Posted: Fri Mar 27, 2020 2:15 pm
by adrian142
while I seem to have understood the concept of connecting multiple inputs and outputs to Voicemeeter, I don't get it when I look at it from inside my DAW. Call me stupid, :ugeek: , but I don't get the mapping.
Let me cycle through all the different Voicemeeter drivers and what it looks like when I select them in Cubase AI.
How do they map to the things inside Voicemeeter.
And why are Inputs and Outputs called the same name?
Is it because an input maps (normally) to the output with the same name?
Please help!
Best, Adrian
VM Potato Insert Virtual.jpg (174.86 KiB) Viewed 12656 times
VM Insert Virtual.jpg (170.29 KiB) Viewed 12656 times
VM AUX.jpg (140.05 KiB) Viewed 12656 times
Re: What are all those INPUTS and Outputs?
Posted: Fri Mar 27, 2020 2:16 pm
by adrian142
Continued:
VM Virtual ASIO.jpg (156.94 KiB) Viewed 12655 times
VM VAIO3.jpg (161.95 KiB) Viewed 12655 times
Posted: Fri Mar 27, 2020 2:20 pm
by adrian142
I think that Virtual ASIO, VAIO3 and AUX are of the same kind.
But what are those 8 inputs and outputs.
Most of the time I get no signal at all.
And it really becomes overwhelming when I look at Potato Insert and VM Insert. The Inserts seem to share a common complexity, too.
Posted: Fri Mar 27, 2020 6:25 pm
by adrian142
Here is a video that shows my problem "live".
I send the desktop audio to all the outgoing channels but inside the daw - nothing!
https://youtu.be/tUtUmd2nb2A
Posted: Tue Mar 31, 2020 8:21 pm
Voicemeeter Virtual I/O are also present as Virtual ASIO Driver (8 channel) as explained in the user manual page 14
the Voicemeeter Virtual ASIO Insert driver present all PRE-Fader inputs to connect a DAW to be used a multi track recorder or VST Host page 58.
