Voicemeeter x32 or x64
Posted: Wed Mar 31, 2021 9:09 am
by Zargan
Hey guys,
just a short question.
Is there any technical difference between the normal version and the additionally installed "x64" version in case of stability?
I just ask because normally...why not... I would use the x64 version. But after a new installation voicemeeter still runs the x32 version. I could change the autostart but maybe there is a reason why voicemeeter just like to start in x32.
This is a little bit irritating. =)
Thanks.
Re: Voicemeeter x32 or x64
Posted: Wed Mar 31, 2021 1:46 pm
by xcasxcursex
Latest versions of VM use the x64 version when you run x64 Windows. I've been using it exclusively since it was an unannounced feature and never seen a single issue with it. Go for it :)
