Voicemeeter causing computer crash after startup
Posted: Sat Dec 12, 2020 5:01 pm
by Stan_h
Greetings,
I had installed the Banana verision of which worked well with my Win 10 PC.
Now, when I startup the software, my compter goes to the dreaded blue screen.
I have tried to uninstall and reinstall the software, but still crashes.
Any help would be appreciated.
Stan
Re: Voicemeeter causing computer crash after startup
Posted: Thu Jul 24, 2025 12:11 pm
by nsf323
I've seen your post re Blue Screen
Did you resolve this issue? as it has just happend to me having moved from Win 10 to Win 11
Posted: Fri Jul 25, 2025 6:35 am
assuming you are using the latest Voicemeeter version (x.1.1.9),
we have a single report about BSOD at the moment and it is due to a particular version of Logitune.
just remove or update this Logitech application, that is disturbing the Windows Audio Stack in a very strange way.
