[SOLVED!] why VMB on Windows 10 turns into static mess
Posted: Tue Oct 27, 2015 10:08 am
Ok I found out why VMB is turning into complete static mess for sound coming in/out of the program.
If you turn off:
-Allow Applications to take exclusive control
-Give exclusive mode applications priority
This messes up the sound
With my USB mic if I turn off both of those, it turns into a absolute static mess.
Turning that off with my Nvidia HDMI out causes all sound from VMB to become garbled crap.
So THAT is why VMB is having all these audio problems with Windows 10, with windows 7 this was not an issue, with windows 10 it is.
I have hereby SOLVED the static issue I was having with input/outputs.
This is probably something that should be noted. Exclusive mode needs to be checked in device drivers if its enabled in VMB as this was not an issue with Windows 7 when I had it installed (Maybe my hardware is unique/weird?)
If you turn off:
