[DEV] using raspberry pis to transmit via vban
hex_1
Good afternoon can anyone tell me how to use https://github.com/quiniouben/vban, i have got it sat in the downloads folder on a brand new raspberry pi3 and really want to be able to do it before I do my next filming next month
thanks hex_1
thanks hex_1
hex_1
Re: useing raspberry pis to transmit via vban
update i have it installed on my pi butand it will recive a transmsion from my computer but it cannot trannsmit when i use [vban_emitter -i 192.168.1.75 -p 6980 -s b1 -n 1 -c 1 -b alsa -r 48000] it gives me error [Error: alsa_read: snd_pcm_writei failed: Input/output error
Segmentation fault]
thanks in advance hex_1
Segmentation fault]
brickviking
I won't answer for the Voicemeeter author, but the application you downloaded is (probably) written by a different person. You have to approach them (or the community associated with them) for support for that open-source program. Some communities are really good and will help you as best they can, and the software looks like a good idea.
If the actual situation is different, then the VoiceMeeter author can correct me. (I'm used to that... heh.)
(Post 15)
(Post 15)
yes but it's the right place for this question... Benoit will come to reply soon.
quiniouben
Hi all, @hex_1 : this is a correct place, or alternatively, you can open an issue in the github project.
To have a better idea of the trouble, you could try to add -l4 option to your command line.
That you have an alsa_read error may tell us the configuration you are trying to use, your device cannot support (48kHz, mono, 16bit (default)).
Could you check if you can open this device with aplay and same configuration ?
That you reach a Seg fault is very unexpected : have you cross-compiled or compiled directly on the raspberry pi ?
Anyway, we will find a solution.
hex_1
i compiled on the same pi i have added -l4 and it is giving this error [ Info: socket_open: opening socket with port 6980
Info: socket_open with port: 6980
Info: audio_init: config is direction in, backend alsa, device , buffer size 1024
Info: audio_backend_get_by_name: found backend alsa
Info: audio_set_map_config: new map config is nb channels 1
Info: audio_set_stream_config: new stream config is nb channels 1, sample rate 48000, bit_fmt 16I
Fatal: alsa_open: open error: No such file or directory
Error: audio_set_stream_config: could not open backend with new config
hope this means something to you
thanks hex_1
thanks hex_1
quiniouben
Sorry for delay, I forgot to enable notifications.
Well, at least, it is more fair, it tells you it cannot open the device.
Then it could be something like there is no device defined as default in your alsa configuration.
One way to test this idea would be to use the exact device name with option -d.
To get the device name "arecord -L" is a good tool.
hex_1
i have used arecord -L and it has given me a long list which part should i use
thanks hex_1
arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
default
sysdefault:CARD=Microphone
Logitech USB Microphone, USB Audio
Default Audio Device
front:CARD=Microphone,DEV=0
Front speakers
surround21:CARD=Microphone,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Microphone,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Microphone,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Microphone,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Microphone,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Microphone,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Microphone,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Microphone,DEV=0
Direct sample mixing device
dsnoop:CARD=Microphone,DEV=0
Direct sample snooping device
hw:CARD=Microphone,DEV=0
Direct hardware device without any conversions
plughw:CARD=Microphone,DEV=0
Hardware device with all software conversions
quiniouben
So, it seems to confirm the lack of defined default device, as if I do the same on my PC I have the following at the bottom of this message, where default is having a description and says which is default.
I would start trying with "-d sysdefault"
$ arecord -L
null
pulse
PulseAudio Sound Server
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC3266 Analog
front:CARD=PCH,DEV=0
Front speakers
hex_1
i have added -d sysdefalt and it hasn't made any change
