I unfortunately am not able to use VoiceMeter to anywhere near its full potential anymore.
I can no longer access any of the Virtual Channels (B1,B2,B3).
I can't access them in Internally in Potato or Via Windows after 1909 Update. (Would have posted this earlier but life things got in the way)
Using FFMpeg to grab Listed Devices in Windows. (Including my own)
[dshow @ 0000012356adffc0] DirectShow audio devices
[dshow @ 0000012356adffc0] "CABLE-A Output (VB-Audio Cable A)"
[dshow @ 0000012356adffc0] "CABLE Output (VB-Audio Virtual Cable)"
[dshow @ 0000012356adffc0] "VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)"
[dshow @ 0000012356adffc0] "VoiceMeeter VAIO3 Output (VB-Audio VoiceMeeter VAIO3)"
[dshow @ 0000012356adffc0] "VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)"
[dshow @ 0000012356adffc0] "CABLE-D Output (VB-Audio Cable D)"
[dshow @ 0000012356adffc0] "CABLE-C Output (VB-Audio Cable C)"
[dshow @ 0000012356adffc0] "Microphone (Logitech G633 Gaming Headset)"
[dshow @ 0000012356adffc0] "CABLE-B Output (VB-Audio Cable B)"
[dshow @ 0000012356adffc0] "Digital Audio Interface (Cam Link 4K)"
[dshow @ 0000012356adffc0] "Microphone (2- Logitech G533 Gaming Headset)"
I also can not access VBAN because I have more then 1 network (I have 5) and it is selecting 3 diff address for some reason making it totally unusable.
This happens on a Clean OS Install as well as multiple re-installs of everything.
This makes the best parts of VB-Audio useless for my uses
Any help or suggestions would be wonderful.
If you need more info specifics drivers, versions all that stuff let me know I don't know how detailed you wish me to be, I can also provide screenshots if need be.
Regards,
The009
