Blame it on recent Windows 10 update... whatever.
Today sometime I lost the Voicemeeter Potato VAIO channel (B1). Checked my sound drivers all others are present. Not sure if I need to uninstall/reinstall VB Potato or somehow reinstall single driver.
Any thoughts?
Ken-W9KB
Missing VAIO drivers/device
Re: Missing VAIO drivers/device
Hi. You could try to reinstall the missing Voicemeeter VAIO using the installer located at C:\Program Files (x86)\VB\Voicemeeter. The installer is named VBCABLE_Setup_x64.exe. Please remember to restart Windows after the installation.
Please let us know if that solves your issue.
W9KB
I was able to fix my problem... found the missing VB VAIO Input/Output device using Device Manager listed under ‘Other Devices’ with a little yellow triangle with exclamation symbol (no particular message otherwise). Right clicked an found an option to search for driver on computer.
Bottom line - driver was found and successfully reinstalled, rebooted, and all appears healed.
Windows can be heavy handed one minute and quite forgiving the next?
Thanks for your feedback,
Ken
Ken
